Activity › Forums › Adobe After Effects Expressions › Scale axis problem
  • Scale axis problem
    Posted by David Baxter on December 12, 2010 at 4:21 pm
    Hello, I’m a new post(er?) here.
    I’m trying to use an expression slider to control a multiplication factor of scale percentage on a layer.
    I got it working on the x axis but can’t figure out the array syntax to address the y axis.
    Anyone help?
    David Baxter replied 15 years, 9 months ago 2 Members · 3 Replies
  • Kevin Camp
    December 13, 2010 at 4:23 pm
    if you just needed to multiply both x & y scale values by the same slider value, you could use something like this for the layer’s scale expression:
    n=effect("Slider Control")("Slider"); // this should be your slider control
    value*n
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • David Baxter
    December 13, 2010 at 6:10 pm
    Hi thanks. Sorry for posting twice, the first took a while to register as I’m new but I thought it had messed up.
    I needed Dans way because I’m controlling multiple parameters, not just scale, so a multiplication factor ranging -1 to 1 seems to work.
    I’m building a little face rig to make a head look like it’s turning left and right and up and down using 2 faders. If anybody is interested hit me up.
  • David Baxter
    December 13, 2010 at 6:15 pm
    Didn’t quite read that properly. Ofcourse this would work also, it’s a bit leaner actually. Just need to stick in an extra multiplication factor at the end if needed.
