Activity Forums Adobe After Effects Scale after effects project like a vector?
  • Scale after effects project like a vector?
    Posted by Jeremy Arimado on August 4, 2013 at 4:16 pm
    I was wondering how i would be able to scale my 720p comp to 1080p without losing any quality.
    It’s just vector layers so i think this should be possible.
    Cheers,
    Jeremy
    Erik Waluska replied 13 years ago 3 Members · 2 Replies
  • Emmanuel Jimenez
    August 5, 2013 at 5:28 pm
    You shouldn’t have any problem as long as you continuously rasterize. You should do some research on that little button, it does alot more than keep vectors crisp.
    I rock.
  • Erik Waluska
    August 5, 2013 at 9:43 pm
    Once you set the continuously rasterize switches for your layers you can use the Scale Composition script. Go to File>Scripts>Scale Composition and then enter the new comp dimensions or scale factor, which in your case would be 1.5.
    Erik Waluska
    EAWmedia
