Activity Forums VEGAS Pro Saving Multiple Keyframes in One Preset.
  • Saving Multiple Keyframes in One Preset.
    Posted by Zinonas Yianni on September 8, 2008 at 9:12 am
    Hello. I have a question about Sony Vegas Pro 8. When I apply a video FX or video event pan/crop on a video, and I customize it with keyframes, I can save a keyframe as a preset. But I can only save a specific keyframe, and not multiple keyframes in one preset. For example, I apply an Invert effect on a video, and i create 2 keyframes (one at the begining and one at the end of the clip.) The first keyframe is 1.000 Blend Amount and the last keyframe is 0 Blend Amount. So when I play the clip, It gets from inverted to non-inverted. I want to save this effect, but I can only save a specifc keyframe, for example the Blend Amount 1.0000. Is there a way I can save multiple keyframes?!
    Jeremy Rasnic replied 18 years ago 2 Members · 1 Reply
  • Jeremy Rasnic
    September 8, 2008 at 5:51 pm
    You can save it (applying the key frame effect to generated media) as a veg file naming it according to the effect. Then whenever you want to use it, open it up in another instance of Vegas and copy the event and paste its attributes to the event you want to show the effect.
    You may also be able to save it as a transition.
    j razz
