Activity Forums VEGAS Pro Saving Issue with 30fps/24fps clips in same project in Vegas Pro 10 Technical advice needed.
  • Saving Issue with 30fps/24fps clips in same project in Vegas Pro 10 Technical advice needed.
    Posted by Eric Seeram on January 18, 2012 at 12:36 am
    Sony Vegas Pro 10 Build A.
    i Have 1080/24fps footage and 1080/30fps footage out of a canon Dlsr in the same project..
    Problem im having when im rendering out as a SonyAVC 1080/1920 hd 24fps i believe it is the 30fps footage doesn’t look correct or doesn’t retain quality very well, yet the 24 looks perfect.
    what settings do u suggest i render out in to retain maximum quality for youtube when using both 24fps and 30fps footage in same project. and also just when rendering out in 24fps with 24 fps footage.lol. HELP
    John Rofrano replied 14 years, 8 months ago 3 Members · 4 Replies
  • John Rofrano
    January 18, 2012 at 12:52 am
    [Eric Seeram] “Sony Vegas Pro 10 Build A. “
    Why? The current version of Vegas Pro 10 is E. What you are seeing could actually be a bug that was fixed. Vegas is usually very good at mixing different frame rates.
    [Eric Seeram] “what settings do u suggest i render out in to retain maximum quality for youtube when using both 24fps and 30fps footage in same project. and also just when rendering out in 24fps with 24 fps footage”
    I would render to 29.97fps using one of the include “Internet” templates. YouTube might be converting it to this anyway.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Eric Seeram
    January 18, 2012 at 8:15 pm
    aside from the version bug fix possibility, any other suggested file format to render the video out in ? unfortunatly i have a cracked version and i am not savvy enough to update to build e. lol
  • Mike Kujbida
    January 18, 2012 at 8:45 pm
    [Eric Seeram] ” unfortunatly i have a cracked version”
    In that case, buy it, come back here with proof and then maybe you’ll get the help that is freely given to legitimate users.
  • John Rofrano
    January 19, 2012 at 4:29 pm
    [Eric Seeram] “unfortunatly i have a cracked version”
    Sorry Eric. As Mike said, we don’t support piracy here. If you like the software, you should buy it. You have no right to steal it.
    ~jr
