Activity Forums Adobe After Effects Saving image with CC Time Blend
  • Saving image with CC Time Blend
    Posted by David Kim on September 1, 2015 at 7:34 am
    Hi guys,
    I am using the CC Time Blend function and am trying to save a picture of the final frame after playing through the entire composition. When I try to use “save frame as” it only saves the current image without the time blending effects. How can I keep the time blend effects while saving a single frame?
    Appreciate your help.
    David Kim replied 11 years ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    September 1, 2015 at 10:53 am
    Some ideas:
    You could try rendering just the last frame (rather than saving a frame as). Don’t know if it works in this case.
    You could render entire movie as a image sequence and then delete all but last frame.
    You could save the RAM preview and extract last frame with Photoshop.
    Or you could do a screen grab (print screen) of the result — if resolution allows. Although you probably compromise some quality if you do that.
  • David Kim
    September 3, 2015 at 2:56 pm
    What I did in the end was just render the entire video clip and then extract the last frame using the new video file.
    Thanks for your suggestions.
