Saving edit list
Posted by Colin Oddy on December 11, 2009 at 12:40 pmIve looked unsuccessfully in the archives for an answer so hopefully someone can help me out please.
Before I delete the files of the current project id like to save the edit list – just in case. can someone tell me how to do that or point me to a tutorial to show me – please.regards 🙂
Colin
Colin Oddy replied 16 years, 9 months ago 3 Members · 6 Replies -
Mike Kujbida
December 11, 2009 at 1:22 pmSaving the veg file is the same thing as saving your edit list.
When you open it again, you’ll be exactly where you were when you last had the project open.
Remember to save often!! -
Joe Mantaratz
December 11, 2009 at 1:28 pmJust to be clear about what you are doing. You want to save the edit list but will delete the files? If you do that then having and edit list will do you know good as it will not be able to locate the source files. If you move the files it will have to find them all over again. Hopefully this is not what you meant to convey.
Colin Oddy
December 17, 2009 at 9:44 pmHi Joe thanks for responding.
Im toldthat the .veg file is efectively the ‘edit list’.
What Im looking to do is remove the wild footage (Id loaded for editing) from the computer. The project is now finished.
However – should I need to make changes to the edit at some time in the future – would I then reload that wild footage, tape by tape and then the saved .veg file would relate accurately to the reinstalled wilds – as if they’d never been removed? is that correct?regards
colin
Colin
Colin Oddy
December 17, 2009 at 9:48 pmHello Mike
thank you for responding.
Aah the .veg file is the edit list. That makes sense.
Colin
Mike Kujbida
December 17, 2009 at 11:06 pmYou’re correct Colin.
It’s been a very long time since I’ve had to do this but, as I recall, you don’t need to load entire tapes.
Open the veg file and, when asked for the footage, I believe that you can tell it to re-capture only the necessary segments.
If I’m mistaken, I ‘m sure that someone will correct me.
