Activity Forums Apple Final Cut Pro Legacy saving custom capture presets
  • saving custom capture presets
    Posted by Paul Nevison on January 23, 2007 at 11:52 am
    Hey there,
    is there a way to save custom capture and sequences presets so that they dont dissapear once you trash your prefs?
    thanks
    G5 DP 2.0 (Power PC)
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    BMD Decklink Extreme 5.8
    PAL Land
    Nick Meyers replied 19 years, 7 months ago 4 Members · 3 Replies
  • Andy Mees
    January 23, 2007 at 12:40 pm
    FCP Attic is an app that lets you back up your prefs and your custom settings … might be useful to you.
  • Bouncing Account needs new email address
    January 23, 2007 at 12:59 pm
    “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP (Pro) & FCE (Express).
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    or
    https://pistolerapost2.com/fcprescue/
  • Nick Meyers
    January 24, 2007 at 2:27 am
    those rescue apps are great,
    but it’s a bit annoying that custom settings dont seem to be saved anywhere but the prefs.
    however…
    if you create an EASY SETUP using your custom settings… then that gets saved as a file.
    MacHD / Library / Application Support / Final Cut Pro System Support / Custom Settings.
    the benefit of having the easy set up backed up over just your prefs is that they are more transportable.
    moving your prefs to another system i have found to be problematic.
    nick
