Saving an AJA Kona 2 PCI-x card ?
We have all of our edit bays on newer PCI-e AJA Cards or IO/HD boxes. A recent small budget project gave me an idea I wanted to run by some of the experts here.
We have a PCI-e based max OSx Server computer that is hooked via PCI-e interface to a large 32TB raid box. Within that box are enough additional PCI-e slots, that I wondered if there were a nice solution to install a KONA 2 card we have on hand. This way, the server computer could be used for occasional overflow editing. I started researching for a “bridge card” that would convert the inboard PCIe slot forward to PCI-x thus allowing my older AJA card to function in the newer computer.
My search has located several options from:
https://www.plxtech.com/files/pdf/apps/ExpApp51_Riser_card.pdf
https://prostores1.carrierzone.com/servlet/beaglesoft_com/Detail?no=189Has anyone had any luck doing such a thing. I’m not out to spend a lot, just thought it might be a way to put a near new AJA PCI-x card back into service for us.
Thanks in advance, Jim
jimj@cumulusent.com
