Activity › Forums › Apple Final Cut Pro › Save RAM with keyboard shortcuts!
  • Save RAM with keyboard shortcuts!
    Posted by Loren Risker on January 24, 2014 at 7:12 am
    Can’t believe I just realized this:
    You can set the keyboard properties in the key command editor. Here’s what I changed:
    Customize keyboard shortcuts:
    Clip Appearance: Clip Labels Only – option-command-w (ram saving mode – no thumbs or waveforms, really speeds it up)
    Clip Appearance: Waveform and Filmstrips – optionss-fit-w (bring back the thumbnails and the waveforms)
    Great way to boost performance quickly. Hope this helps someone!
    OutOfFocus.TV – Original series, music videos, mini-docs.
    Loren Risker replied 12 years, 7 months ago 4 Members · 5 Replies
  • Nikolas Bäurle
    January 24, 2014 at 9:36 am
    I don’t think this was possible with older versions, or I was looking for the wrong command…
    Thanks for the info!
    “Always look on the bright side of life” – Monty Python
  • Patrice Freymond
    January 24, 2014 at 11:08 am
    This since 10.0.9 i believe, with alt-ctrl 1 to 6 to switch Timeline views.
    I still wish there was a way to expand/reduce clip heights via shortcut too…
    Patrice Freymond
    Editor  Certified Trainer FCP7/X
    Post Consultant
    Always learning…
  • Nikolas Bäurle
    January 24, 2014 at 12:57 pm
    [Patrice Freymond] “I still wish there was a way to expand/reduce clip heights via shortcut too…”
    I hope they get that fixed soon.
  • Nick Toth
    January 24, 2014 at 2:06 pm
    Control Option up and down arrow will cycle through the views. No key commands for clip height in the timeline however. I have F1 and F2 mapped to Clip Labels Only and Clip Waveforms Only. F3 is mapped to Large Filmstrip. I find those three the most handy.
    anickt
  • Loren Risker
    February 3, 2014 at 8:48 pm
    Didn’t realize how much I screwed up this post:
    Search clip appearance in the keyboard command editor.
    Set Clip Labels Only (I used command-option-w) (ram saving)
    Waveforms and Filmstrips (I used command-option-f) (back to normal
