Activity › Forums › Apple Final Cut Pro Legacy › Save Edits but Change Sequence Settings
  • Save Edits but Change Sequence Settings
    Posted by Alexa Lee on June 20, 2008 at 10:11 pm
    Is there a way to use the same edits in two different sequences? The sequences have different settings. For instance, you’ve edited video in a sequence set for 640 x 480. With all the same footage, you want to edit in a sequence that is 1280 x 720.
    We’ve tried copying the edits in one sequence and pasting them into the new sequence of different settings. That doesn’t seem to work so smoothly–the video still has the same “memory” as the first sequence. Do we need to re-edit the whole thing? Why can’t we just change the sequence settings?
    Michael Sacci replied 18 years, 3 months ago 2 Members · 1 Reply
  • Michael Sacci
    June 20, 2008 at 11:12 pm
    I would edit in the HD format and then just export a down converted version of the movie.
    The other would be to try a media management and down convert the footage to the SD.
    Do you have the 2 different versions of the clips?
