Activity Forums Apple Final Cut Pro Legacy SATA looses connection
  • SATA looses connection
    Posted by Per Ottesen on September 18, 2006 at 6:45 pm
    Can You help me with the following problem:
    A customer use FinalCut Pro 5.1 on a MacBook Pro with a Firmtek SATA cabinet with two disks and the express card to the MacBook Pro.
    It works fine when he capture from the camera, but when he try to connect from FCP
    David Roth weiss replied 20 years ago 2 Members · 1 Reply
  • David Roth weiss
    September 18, 2006 at 10:25 pm
    Its possible that Firmtek has a firmware update for the controller card or another solution that will solve the problem. You should write support@firmtek.com and ask Kim for a solution. She is very helpful. I own several of their products and Kim has helped me with any issues.
    DRW
