Activity › Forums › Apple Final Cut Pro Legacy › SATA drives for FCP 5.1 on a Mac G5 Quad
  • SATA drives for FCP 5.1 on a Mac G5 Quad
    Posted by Greg Ball on September 15, 2006 at 4:22 pm
    Can anyone suggest which way to go with SATA drives on a Mac G5 Quad. I’m considering between G-Sata, MacGuru or Granite, but I’d love to hear other suggestions.
    I edit on SD Beta SP mostly, and Mini DV.
    Thanks for your help.
    Greg
    Mrvideo replied 20 years ago 2 Members · 1 Reply
  • Mrvideo
    September 16, 2006 at 1:38 pm
    I recommend the Highpoint X4 external 4 bay (removable) with their RocketRaid 2322 PCI Express SATA II controller. That card takes one 4-lane PCI-express slot and hosts up to two external enclosures with Infiniband. The real value of this card is that it uses on-board formatting and make RAID 0-1-5 and 10 available. Typically when using the Apple DiskUtility to RAID disks into a set, they are setup by the operating system and it is very easy to loose that setup when updating the OS. With the RocketRaid card, you never loose the RAID set.
    Check it out at http://www.thefinalcutstore.com
