Activity › Forums › Boris FX Sapphire › Sapphire v5 not working on my win7 64bit
  • Sapphire v5 not working on my win7 64bit
    Posted by Kazumi Hatori on June 30, 2010 at 8:49 am
    I got win7, and AE CS5,
    I downloaded the sapphire v5 trial to installed,
    First, the default install location (at mediacore) didn’t work for CS5 to recognize the plugin, so I moved them to Aftereffect/support files/plug-ins, and it does.
    But I found all effect just don’t work, I believe even in trial they should work(maybe have 2 red lines?).
    After I applied the effects, the plugins either blank out my video, or give a pop-up:
    “After Effects error: parameter count mismatch in plug-in effect ‘s_xxxxxxxx'”
    I uninstalled the sapphire v2 before I install v5, what should I do??
    Please help, thanks.
    Kazumi Hatori replied 16 years, 3 months ago 2 Members · 2 Replies
  • Gary Oberbrunner
    June 30, 2010 at 12:39 pm
    Hi Kazumi; thanks for reporting this. This can happen if your NVIDIA video driver is too old. We will have a fix in the next Sapphire AE maintenance release, but in the meantime you can just update your NVIDIA video driver and you should be all set.
    — Gary
  • Kazumi Hatori
    July 3, 2010 at 7:14 am
    oh i updated the driver and it’s working fine! thanks!
