Activity › Forums › Sony Cameras › SanDisk Ultra II Class 4 Emergency Plan
  • SanDisk Ultra II Class 4 Emergency Plan
    Posted by Tim Kolb on May 16, 2009 at 4:22 pm
    Interesting…
    …a week after seeing the SanDisk Class 4 failure thread…I had one 16GB go unrestorable. second use/second format
    More than half full… I thought from the existing thread that things were pretty much hopeless. The EX software said the media needed to be restored in the camcorder, the camcorder reported that it was unrestorable. The EX software wouldn’t transfer any of it, and even Windows Explorer wouldn’t move the data off the card.
    But…I could see the damn QT files and even though QT wouldn’t open them (ANY of them, not just the last one), on a long shot, I decided to open Premiere Pro and see if the editor would load the EX1 QT essence files…
    …it imported and played all but the last clip.
    So…next problem. saving it out.
    I thought I’d try to be clever and bring all the shots onto the timeline and trim the project (in order to write all the clips in their native format to another location…). Failed…unknown error.
    So…I took the timeline with all the clips and tried to export the whole works to an H264 file through the Adobe Media Encoder…somewhere about 3/4 of the way through I had another unknown error.
    Now I’m putting each clip on the timeline separately and processing each out of PPro. I’m messing around with a couple different codec options, and I’m still not convinced that I can’t do some sort of Project trim if I can disable the XML read/transfer process and restrict the trim to using the file essence…
    For those of us in this predicament, this might at least offer a last-ditch option for those of you with critical media on one of these SDHC cards…
    I’ll post any other particulars I uncover…
    TimK,
    Director, Consultant
    Kolb Productions,
    Martin Phillips replied 16 years, 9 months ago 8 Members · 20 Replies
  • 20 Replies
  • Tito Haggardt
    May 16, 2009 at 7:11 pm
    you might try this
    shoot 10 sec on a SxS card and put it in you sony browser
    drill down the BPAV file> CLPR till you get to the Quicktime file and delete it. then go to the Sandisk and copy all the Quicktime files you have and paste them onto the SxS card in the browser. when you refreash the browser they might open.
    or not, i have never had this problem so i don’t know
    aloha
    tito
  • Rafael Amador
    May 17, 2009 at 2:19 am
    Once you have the MP4 files, you just need the SONY Clip Browser to re-package them in a new BPVA.
    rafael
    http://www.nagavideo.com
  • Tim Kolb
    May 17, 2009 at 12:17 pm
    [Rafael Amador] “Once you have the MP4 files, you just need the SONY Clip Browser to re-package them in a new BPVA.
    rafael”
    Tell me more Rafael… I have the essence files, but I can only move them off the media in Windows Explorer through copy/paste…
    PPro seems to import everything on the media, but will only play back everything but the last four clips…they create an importer error.
    I’d rather not transcode them if I don’t have to, but I’m not aware of how to use the clip browser to reconstruct the infrastructure. The clip browser keeps telling me I need to put the media back in the camera to restore…and as I said earlier, that doesn’t work.
    TimK,
    Kolb Productions,
  • Rafael Amador
    May 17, 2009 at 1:35 pm
    Hi Tim,
    You just need to import the MP4 to the SONY Clip Browser.
    The application build a BPAV with those files.
    You can upload the new BPVA to a SxS card and use the SONY Transfer as usual.
    Even more easy, put the BPVA inside a folder in your finder and point the SONY Transfer to that folder.
    I was able to recover everything from inside two SDHC cards. Except the two corrupted MP4 that made the cards fail.
    Tim, I don’t remember how i did it but was really easy. I will try to do it again and i post you.
    rafael
  • Rafael Amador
    May 17, 2009 at 2:38 pm
    Hi Tim,
    I tried again and it works.
    I don’t know how it looks the SONY Clip Browser in a PC.
    In a Mac looks like that:
    The only thing I’ve done is create a new folder. I’ve call it Recover.
    Then IMPORT the clips to that folder.
    When you import the MP4, the Clip Browser creates a BPAV inside that folder.
    You can add new MP4 and the BPVA is updated with each import.
    After that I’ve open the SONY Transfer tool and “Add Source”.
    The “Recover” folder shows like any SxS card.
    Just select and convert.
    Rafael
  • Tim Kolb
    May 17, 2009 at 7:23 pm
    Thanks a bunch Rafael…I’ll be giving this a shot.
    TimK,
    Kolb Productions,
  • Tim Kolb
    May 18, 2009 at 12:44 pm
    Hmmm…
    ‘Import’ works with the non-corrupt MP4 essence files. Nice.
    The advantage over messing around with Premiere Pro is of course no transcoding is necessary.
    I had four clips that were corrupt and simply lost…in this case, not a crippling loss because it was short b-roll shots on the card. If it had been a lengthy interview, I’d have been hosed.
    Thanks Rafael.
    (I’m considering attempting a re-format in the computer to see if the card can be salvaged for non-critical use…seems like a useful exercise)
    TimK,
    Kolb Productions,
  • Rafael Amador
    May 18, 2009 at 12:55 pm
    Hi Tim,
    You can do the formating in your computer, then when you put the card in the camera will ask you to Restore it.
    I give up using the Class 4. Too risky. I will try to get some Transcend. Craig haven’t had a single problem with them.
    Is a pity that Christmas still so far away. I have ready the present for some of my friends.
    Best,
    rafael
  • Tim Kolb
    May 18, 2009 at 1:15 pm
    Yes…having one fail so quickly is a cautionary note for sure.
    These cards were tested by the MxM folks as well…it’s pretty tough to see the future.
    TimK,
    Kolb Productions,
  • Don Greening
    May 21, 2009 at 6:59 pm
    A new SDHC class 10 card from Panasonic just announed:
    https://www.dpreview.com/news/0905/09052102panasonicclass10sdhc.asp
    – Don
