Activity › Forums › Sony Cameras › Sandisk 64 GbSDXC card compatibility with the EX-1
  • Kevin Patrick
    October 13, 2011 at 11:49 am
    It may not be compatible with the EX1. The cards need to be fast enough to support the bit rate.
    I purchased Sony’s Memory Stick 32GB Pro-HG Duo HX.
    They work fine, no issues.
    https://www.adorama.com/SOMSHX32A.html
  • Miguel Coyula
    October 13, 2011 at 12:20 pm
    I was told by the sales person that I should be able to do it as long as I don’t overcrank.
  • Michael Palmer
    October 13, 2011 at 2:11 pm
    CHeck to see what firmware you have on the EX1 and up grade to the latest. If you have an original EX1 they need a special firmware needs to be installed before you can load the latest.
    Good Luck
    Michael Palmer
  • Kevin Patrick
    October 13, 2011 at 2:35 pm
    I forgot about that. I believe Michael is correct, you need to make sure your camera has the latest FW.
    https://pro.sony.com/bbsc/ssr/micro-xdcam/resource.downloads.bbsccms-assets-micro-xdcam-downloads-XDCAMSoftwareDownload.shtml
    In the release notes you they do post some limitations. You can’t record slow motion with the media adapter. You need SxS cards.
  • Miguel Coyula
    October 13, 2011 at 5:30 pm
    Thanks, it might be very well be that. However the link here is for the EX-1R does it make a difference from the EX-1?
  • Bob Tompkins
    October 14, 2011 at 2:39 pm
    The EX1r is easier to update the firmware than the EX1. You have to be at a certain firmware level to be able to upgrade by yourself. Maybe Ian will pop on here and explain and point you to the link. It has been discussed here before.
  • Bob Tompkins
    October 14, 2011 at 2:40 pm
    Search “EX1 firmware upgrade”.
