Activity › Forums › Adobe After Effects › Sand text
  • Posted by Danny Bassett on August 5, 2011 at 6:34 pm
    So Im new to after effects ( been using it for 18 months) but i understand the basics and more advanced stuff. What i dont understand is the problem im having rendering this tutorial:
    https://library.creativecow.net/articles/eriksson_emanuel/sand.php
    I followed it exactly, except i am using a 1920×1080 background. Its wants to take 1330 hours to render a 4 second piece. after effects is also using hardly any cpu time. the station is a 2.93 i7 imac with 8gb ram.
    Its does the same thing on the quad core mac pro.
    its not settings because i just created, render and 1080 comp with particle world, it rendered, maxed cpu while rendering.
    all opengl is off.
    can anyone shed some light on this?
    thanks,
    Danny
    Danny Bassett replied 15 years, 1 month ago 2 Members · 2 Replies
  • Kevin Camp
    August 5, 2011 at 9:13 pm
    particle playground is not natively multi-threaded, nor can it use ae’s ‘render multiple frames simultaneously’ option (as most other effects will), so any comp’s that use that effect will render more slowly on multi-core machines… approximately at the speed of a single core.
    there are a few other effects that can do this. you might check out some of these other tutorials here (and i’m sure you can find many more on the web):
    https://library.creativecow.net/search.php?q=text+sand&order=t&view=&cat=
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Danny Bassett
    August 5, 2011 at 11:55 pm
    AE 10 i.e. CS5
    no video footage.
    I have a png with a simple logo.
    png dupllicated, and put particle playground on one of them with layer exploder, particle size going from .5 to 0.
    (ive also tried with plain text)
    4 second comp.
    Thats it.
    what gives?
