Activity Forums VEGAS Pro Samsung Monitor for Video Editing??
  • Samsung Monitor for Video Editing??
    Posted by Ray Sherman on April 11, 2008 at 3:47 pm
    After reading tons of reviews, it seems that Samsungs are pretty hard to beat. If you use a Samsung monitor for video editing what would you suggest and what to stay away from? I want to setup a two monitor system one for editing with the other for viewing. I need both monitors to be capable (switchable) of viewing 4:3 and 16:9 aspect ratios correctly.
    I am currently looking at the following monitor, but I’ve heard that TN monitors are a no no. Is this true? Other than that I like the specs; 2ms, digital/analog interface, etc.. Please give me your professional opinion. Camcorders that I use are the Sony DCR-VX2100 and the Sony HDR-HC7 Thanks, Ray
    P.S. I know about the “S” and “A” series issues on this particular monitor. S is preferable.
    Samsung 226BW
    Panel Type: a-si TFT/TN
    Viewable Size: 22.0″ Wide
    Pixel Pitch: 0.282mm
    Brightness (typical): 300 cd/m2
    Contrast Ratio (typical): 3000:1 DC
    Response Time (typical): 2 ms (G to G)
    Viewing Angles (H/V): 160/160
    Native Resolution: 1680 x 1050
    Aspect Ratio: 16:10
    Maximum Color: 16.7M
    Interface: Analog/Digital
    Input Video Signal: Analog RGB, TMDS Digital Link, DVI
    Sync Type: Separate H/V, Composite, SOG
    Input connetcors: 15-pin D-sub, DVI-D
    Plug and Play: DDC 2B
    Power Consumption: 55 Watt (max.), <2 watt (DMPS mode
    Stand Type: Simple
    Cabinet Color: Piano black
    VESA Wall Mount: 100 mm
    Magic Technologies: MagicTune with asset management, MagicSpeed, Magic Contrast, MagicBright 3
    Special Features: DVI (HDCP), Swivel and tilt
    Dimensions (W x H x D): 20.3" x 16.6" x 8.6"
    Ray Sherman replied 18 years, 5 months ago 4 Members · 5 Replies
  • Ray Sherman
    April 11, 2008 at 9:32 pm
    What’s your thoughts for two of these for video editing? One as a DVI with the other set up as analog RGB for viewing.
    Samsung 2253BW
    Display
    Screen Size: 22″
    Brightness: 300 cd/m
    Contrast Ratio: DC 8000:1 (1000:1) (Typ.)
    Response time: 5 ms, 2 ms (GTG)
    Viewing Angle (Horizontal/Vertical): 170/160 (CR>10)
    Signal Input
    Video Signal: analog RGB, DVI
    Sync. Signal: separate H/V, composite, SOG
    Connector: 15 pin D-SUB, DVI-D
    Power
    Power Consumption: 45 Watts
    Stand By Power (DPMS): < 1 W Features Plug & Play: DDC 2B Multimedia Speakers: N Special Features: MagicBright3, off timer, image size, color effect, customized key, MagicWizard & MagicTune with AssetManagement, Windows Vista Premium, DVI with HDCP, safe mode (DownScaling in UXGA) Stand Function: swivel, tilt
  • Leslie Wand
    April 12, 2008 at 2:50 am
    use 2 x 206bw’s. very happy. anything larger would be (for my purposes) overkill, and probably too big for comfort.
    they’re 1680*1050, but i’m more than pleased with hd viewed on them.
    i still monitor with a sony crt, and can’t see myself in the near future using any lcd for cc, etc.,
    leslie
  • Danny Hays
    April 13, 2008 at 7:13 pm
    I use a 32″ Samsung LCD HDTV for my second monitor. It’s only 1360 – 768 but thats what most medium HDTVs are. The larger ones should be 1920 – 1080 and a decent video card will handle it. Plus there’s a ton of other inputs for camera, DVD’s VCR whatever you have.
  • Mike Kujbida
    April 14, 2008 at 12:06 am
    Ray, on a recent monitor discussion on the Sony Vegas forum, for a variety of reasons, most folks did not recommend the Samsung monitors.
    The Westinghouse L2410NM (24″ – 1920 x 1200) was highly recommended.
    Sam’s Club apparently has it for $299 right now.
  • Ray Sherman
    April 14, 2008 at 12:34 am
    Thanks Mike, I’ll check it out.
