Activity Forums Adobe After Effects sampleImage returns inaccurate result?
  • sampleImage returns inaccurate result?
    Posted by Jeremy Paul on August 20, 2017 at 9:05 pm
    I’m playing around and stumbled upon this tutorial that uses greyness of a pixel to determine scale: https://www.youtube.com/watch?v=4OQN2mHQuD0
    To get R value of a pixel it uses sampleImage() method. It samples the central point of a layer. I found it strange that even though the central point is still 100% black, scaling of a shape layer already occurred. Check this image at
    t=9m26s
    for example.
    The expression in question:
    sampleSize = [1,1];
    samplePoint = thisComp.layer(“Control Layer”).transform.position; // it is [960,540]
    sampleColor = thisComp.layer(“Control Layer”).sampleImage(sampleSize,samplePoint)[0];
    [sampleColor*100,sampleColor*100];
    What am I missing here?
    Leopoldo Perizzolo replied 9 years ago 2 Members · 1 Reply
  • Leopoldo Perizzolo
    August 26, 2017 at 2:57 pm
    You simply switched the two arguments of the expression in sampleImage (just like the video did..)
    It should be:
    sampleImage(position, radius), and in your case:
    sampleColor = thisComp.layer(“Control Layer”).sampleImage(samplePoint, sampleSize)[0];
    Hope it’s all clear.
    Leopy
