Activity Forums VEGAS Pro Same/correct sizes of images?
  • Same/correct sizes of images?
    Posted by Emil Niemi on August 19, 2010 at 10:52 am
    I’m making a video where i put together pictures (transparent PNG and GIF animations).
    When i import these they’re getting huge, so i’m making them manually smaller with the pan/crop tool.
    Problem is just i would like to make them the original size, and then be able to maybe scale it up in % so i can get exactly correct size of everything, so not an image is bigger than it should be.
    So, how do i do this?
    This movie i’ll also do in the 3D world, so i’ll make the layers to 3D and i know i maybe can change the size in that tracker too.
    What’s best way to do this?!
    [Edit]
    Also, i tried go to the 3D track motion thing where i can put the layers in 3D space, rotate etc.
    Here i putted off the aspect ratio and added the width and height as my picture had.
    But it becomes problem, it doesn’t fit the original image, the aspect ratio isn’t correct.
    Emil Niemi replied 16 years ago 2 Members · 4 Replies
  • John Gordon
    August 19, 2010 at 8:17 pm
    use the event pan/crop tool, right click and select match output aspect and then resize there and then use track motion for 3d placements
  • Emil Niemi
    August 19, 2010 at 10:55 pm
    Aah okay thanks.
    But, just tried it fast on an image of a mountain, and it cutted it off abit, thet crop was too small 😐
  • Emil Niemi
    August 20, 2010 at 9:19 am
    Just tried it out some more.. And i found out this doesn’t really go to the original size at all.
    If i have the crop pretty small, then i rightclick and takes “match output aspect” then it becomes pretty small, nothing really happends.
    If i have the crop pretty big and do the same, it will stay big.
    So it doesn’t really matter..
    Soo is there any solution for this? ;S or is this feature not exist
  • Emil Niemi
    August 20, 2010 at 8:11 pm
    Sooo anything does work to fix this? Or is this something that sony vegas never added?
