Activity › Forums › Adobe Premiere Pro › Same source footage, multiple editors
  • Same source footage, multiple editors
    Posted by Don Hertz on March 4, 2019 at 8:06 pm
    I have multiple editors that are going to be working on different Premiere projects, but each using the same source footage to pull clips from in building their sequence.
    Can I safely have one copy of the source footage on a shared NAS with all of the them reading it at the same time but each writing to their own projects or do I need to make a copy of the source footage for each editor?
    Thank you.
    Don
    Don Hertz replied 7 years, 7 months ago 3 Members · 5 Replies
  • Oliver Peters
    March 4, 2019 at 8:29 pm
    [Don Hertz] “Can I safely have one copy of the source footage on a shared NAS with all of the them reading it at the same time but each writing to their own projects”
    Yes. Just make sure you have the bandwidth for everyone to be working at once.
    – Oliver
    Oliver Peters – oliverpeters.com
  • Don Hertz
    March 4, 2019 at 8:37 pm
    Thanks Oliver.
    Don
  • Trevor Asquerthian
    March 4, 2019 at 10:05 pm
    There’s a bunch of posts about shared storage on the cow … https://bfy.tw/Maht
    Avid’s Nexis is a good option for shared storage – not super expensive any more.
    As an editor I’d always rather use Avid in shared environments though (TBH I’m pretty much back on Avid mostly, now they’ve got linked media and editable groups).
  • Oliver Peters
    March 5, 2019 at 12:24 am
    A lot of it comes down to budget and system demands. For example, if you are dealing mainly with Premiere’s internal proxy workflow (or FCPX’s proxy for that matter), then you aren’t taxing the system much. OTOH, if you are constantly dealing with 4K native media, it’s a whole different story. In the Premiere world, I would suggest LumaForge or QNAP as viable options. Each company has several different ranges of models, with a long list of satisfied customers. Likewise, Avid Nexis Pro is also something to consider for a small Premiere-based shop.
    – Oliver
  • Don Hertz
    March 5, 2019 at 2:22 am
    We typically work at lower data rates and have a nice Nexis set up that we use with Premiere. 4K at higher data rates on a shared solution would be great, but unfortunately exceeds our budget. We keep higher data rate “finishing” work on systems with fast direct attached arrays. Everything else is done off the Nexis.
    Don
