Activity Forums Maxon Cinema 4D Same object positioned on multiple points
  • Same object positioned on multiple points
    Posted by Julian Bremann on January 2, 2019 at 8:55 pm
    Hi, I have a points cloud mesh and i want to position on each point an object, the same object. I know I can use expresso to position an object to one point but wonder if, and if so how, to position the same object to all the points. let’s say there’s a cube mesh and i’d want to have a sphere on each of the corners of the cube. I could duplicate the expresso for each point, but if i have hundreds of points i’d like to be able to put a cube to on all of them just with one expression versus create hundreds of them..
    thanks
    Julian Bremann replied 7 years, 8 months ago 2 Members · 2 Replies
  • Brian Jones
    January 3, 2019 at 4:16 am
    with Mograph and the Cloner it’s very easy, which is probably why it’s not otherwise… if you don’t have Studio or Broadcast it can be done with XParticles so it might be possible with Thinking Particles
  • Julian Bremann
    January 3, 2019 at 5:41 am
    Got it, thanks Brian.
