Activity Forums Avid Media Composer Same Audio Goes Offline At Launch
  • Same Audio Goes Offline At Launch
    Posted by Bob Zerweck on May 27, 2015 at 6:35 pm
    I’ve been working on a feature as an assistant editor for several months right now but lately we’ve been having an issue on multiple computers that I can’t seem to figure out.
    For some reason, one of our shots, the same one, goes offline every time the project is opened up, just the audio. I relink the shot easily, work as normal, but the next time the program launches the file is offline again. I have tried rebuilding the databases to no avail. Has anyone experienced anything similar like this?
    AVID: 8.3.1
    Project: 23.976 1080p, working with 115 DnxHD files.
    Computer: OSX 10.9.5
    Thank you guys for your help.
    Michael Phillips replied 11 years, 3 months ago 2 Members · 3 Replies
  • Michael Phillips
    May 27, 2015 at 7:05 pm
    How was the clip created in the first place? And was it done via an ALE import and link to media?
    Michael
  • Bob Zerweck
    May 27, 2015 at 7:09 pm
    Thanks for the response,
    It was transcoded in Redcine X, dnxhd 115. I imported the resulting ALE after copying over the mxf files into Avid Mediafiles.
  • Michael Phillips
    May 27, 2015 at 7:17 pm
    I never recommend just using the ALE form a third party transcode to relink to media as I always hear about unlinking such as this. The preferred and recommended method is to first import the AAF files also generated by Redcine X Pro, then merge the ALE into the master clips for the additional metadata. AAF caries the parent/child relationship and directly links to the MOB ID’s in the mediafiles that is not available by ALE alone.
    A lot of this is covered here, and there is a rather detailed RED section:
    https://www.avid.com/static/resources/documents/whitepapers/digital_camera/digital_camera_workflow_whitepaper.pdf?elq_mid=10041&elq_cid=10546672
    Michael
