Activity › Forums › Avid Media Composer › Same as Source export at 352 x 243
  • Same as Source export at 352 x 243
    Posted by Demi Ray on December 20, 2008 at 12:21 am
    Exporting my current project as “Same as Source” gives me a 352×243 S resolution result.
    Footage is standard DV 720×480. I’ve never run across this before.
    I tried everything I could think of.
    Trying to isolate the issue, I thought perhaps it was the graphics from Marquee I used. I used Avid’s Marquee Title Tool for the first time. However, exporting 3-5 seconds from a portion of the sequence with absolutely no graphics and with the least tracks (1 video; 2 audio), I ended up with the same result: 352×243.
    Oddly, I did manage to get 2 small segments to export as Same as Source (SAS) at 720×480 — with no new re-traceable pattern. I did nothing different when I got 720 than the times I got 352. So, what’s triggering it to interpret it as S resolution when it does?
    If I have to customize the export to get it to 720, which is doable, I don’t get a clean same as source export, no matter which compression I choose or do not choose.
    How do I trace the root of what’s causing 720 DV to be interpreted as S Resolution?
    Demi Ray replied 17 years, 9 months ago 2 Members · 3 Replies
  • Demi Ray
    December 20, 2008 at 4:26 pm
    I figured it out. Nevermind. Thanks for posting.
  • Jon Zanone
    December 23, 2008 at 9:52 pm
    So what was it? It’s useful for folks searching the forums…
    Jon
    “Jamming our heads full of figures and angles
    And telling us stuff that we already know”
    Willie The Wandering Gypsy & Me
    Billy Joe Shaver
  • Demi Ray
    December 23, 2008 at 10:36 pm
    I thought you’d never ask.
    I certainly did search and search before I posted my question. Here’s one for the archives.
    Avid was reading the entire sequence as S resolution and exporting in that corresponding size because of 3 out of several titles created in the Title Tool. It wasn’t the Marquee Tool as I had suspected. As soon as I isolated them out, it returned to DV 720 size when exporting. It required micro-surgery because I had no idea what was triggering it, and not all the Title Tool creations were S resolution.
    The S resolution titles shared this in common: shadow effects. For what that’s worth.
    So, when that happens, something, anything is in S resolution. One frame in S resolution, apparently, will trigger the whole sequence to be interpreted that way.
    That has been my experience. My micro-surgery gloves have been put to rest. Hallelujah.
