Activity Forums Adobe After Effects Same animation preset, different outcomes
  • Same animation preset, different outcomes
    Posted by Wouter Van den berg on September 18, 2011 at 5:46 pm
    Forgive me for asking but I wouldn’t know where else to go.
    I use the Animation Preset under Transitions – Movement called Slide – Straight. This is what I do:
    1. I create a text layer and enter my name in the middle.
    2. I apply the Slide – Straight animtation preset
    3. I hit play.
    4. The animation plays as expected: the text slides from OUTSIDE the comp to its original position.
    Now, if I try the same with my vector graphic (.ai), something else happens. Once I apply the preset on a vector graphic, After Effects doesnt place the vector graphic outside the comp but instead it places the graphic a bit to the left but still in the composition.
    Does anyone have any idea why the vector graphic doesnt go outside the screen like the text does when the Slide – Straight preset is applied?
    Wouter Van den berg replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
