Activity › Forums › Event Videographers › Sachtler Video 14 counterbalance problem
  • Sachtler Video 14 counterbalance problem
    Posted by Erik Waluska on May 1, 2010 at 12:05 am
    Hello,
    I just purchased a used Video 14 mk II head and I think there may be a problem with the counterbalance because when I try to tilt up/down the spring fights very hard against the tilt and tries to return to center. I mean REALLY hard. And it doesn’t exactly return to center, it rests tilted back about 5-10 degrees. The only adjustment for the counterbalance that I can see is the red knob on the side that only has two positions, and neither of them make much of a difference. There doesn’t seem to be any way to disengage the spring either. I’ve used Sachter tripods many times before and they normally stay where you point them but I know this is an older model so I don’t know if it’s supposed to be this way or if it’s broken.
    Any advice would be much appreciated.
    Erik Waluska replied 16 years, 5 months ago 1 Member · 1 Reply
  • Erik Waluska
    May 1, 2010 at 5:15 pm
    Here are some images that may help.
