Activity Forums Blackmagic Design S-Video setting missing from Decklink panel?
  • S-Video setting missing from Decklink panel?
    Posted by Jim Leonard on August 6, 2008 at 8:11 pm
    According to https://www.blackmagic-design.com/support/detail.asp?techID=157 I should be able to capture an S-Video (Y/C) source using my DeckLink SP using an adapter cable. However, I just installed the latest WinXP driver (6.7.2) and all I see for input selection are the following:
    Y, R-Y, B-Y Video & Analog XLR Audio
    NTSC/PAL (Y In) & Analog XLR Audio
    Isn’t there supposed to be an “S-Video” selection? If so, what’s wrong? If not, what setting am I supposed to use?
    Jim Leonard replied 18 years ago 2 Members · 3 Replies
  • Jim Leonard
    August 15, 2008 at 6:22 pm
    Bumping this up again as nobody has responded — I thought BlackMagic support monitored these forums, do they not? Should I contact support directly?
    I can put s-video into my scan converter and then my scan converter’s component to the DeckLink SP, but I would much rather avoid the generational loss in doing that and just pump s-video into the DeckLink SP. See previous post for what I’m seeing; am I doing it wrong?
  • Kristian Lam
    August 19, 2008 at 12:28 am
    Hi Jim,
    The DeckLink SP does not support S-video input. The tech note specifically refers to the DeckLink HD Extreme, Multibridge Pro and Multibridge Eclipse.
    regards
    Kristian Lam
    Blackmagic Design
  • Jim Leonard
    August 19, 2008 at 2:51 am
    I have many hundreds of hours of archival footage that is only available via an S-video out connection. I love the uncompressed 10-bit quality I get from the DeckLink SP; what is the cheapest product Blackmagic offers that will let me capture s-video?
