Activity Forums VEGAS Pro S key
  • S key
    Posted by Jack Gill on April 16, 2017 at 8:49 pm
    My S key (split) is erratic. Sometimes it works fine and then stops working. I have to close down and open back up to get it working again. Frustating.
    Graham Bernard replied 9 years, 5 months ago 3 Members · 2 Replies
  • George Dean
    April 17, 2017 at 12:58 am
    Hi Jack,
    You may want to do a program reset. From the desktop, hold down Shift+Ctrl keys and double left click on the program icon. Before clicking ‘Yes’, be sure to check ‘Delete all cached application data.’ That will set your program back to installation defaults and delete any application data which may have built up and may have gotten the program confused after while.
    Best Regards…..George
  • Graham Bernard
    April 17, 2017 at 3:17 am
    [Jack Gill] “My S key (split) is erratic. “
    Are you absolutely sure you have clicked on the Event/s or have Selected the Events needing to Split? Also, have you got Quantize to Frames enabled?
    * Grazie
