Activity Forums AJA Video Systems Running into Kona 3 problems that require hard reset
  • Running into Kona 3 problems that require hard reset
    Posted by Paul Escandon on October 26, 2007 at 7:07 pm
    We’ve just upgraded to 8-core Mac Pros with Kona 3 cards and I’m running into a problem every so often where the Kona 3 will not output video properly and the only way to fix the problem is to shut down (not reset) and manually turn the computer back on. When the Kona 3 is exhibiting this problem the output on the screen is generally garbled.. but never the same way or the same color. Also, trying to use Final Cut almost always results in a crash…
    As of now this is just a hassle – but I’m hoping it is not a sign of a bigger problem to come or some hardware or software incorrectly configured.
    The question that I have is does any one know of a way to potentially “Reset” the Kona settings or have it re-load into the system without having to do a hard reset? I can’t seem to figure that out if there is such a way…
    Thanks.
    Paul Escandon replied 18 years, 11 months ago 3 Members · 8 Replies
  • 8 Replies
  • Gary Adcock
    October 26, 2007 at 9:03 pm
    Ok
    what OS, FCP and Kona Drivers
    it is not possible to read your mind on the config?
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Jeremy Garchow
    October 26, 2007 at 10:06 pm
    Have you run the PCIe Config Utility?
  • Paul Escandon
    October 26, 2007 at 10:34 pm
    My Kona drivers are 3.4, my OS is 10.4.10, and I’m running Final Cut 5.1.4.
  • Paul Escandon
    No, can you please tell me what/where this utility is?
  • Jeremy Garchow
    October 26, 2007 at 10:49 pm
    HardDrive > System > Library > CoreServices > Expansion Slot Utility.app.
    Select option#2 and restart.
    Jeremy
  • Gary Adcock
    October 26, 2007 at 10:57 pm
    the 3.4 drivers are not recommended for 10.4.10 and QT 7.2 but the upgrade wants an intel processor.
    gary adcock
    Studio37
  • Paul Escandon
    October 26, 2007 at 11:10 pm
    Oh yes I did just try this after reading it on the AJA site. I’ll see if I still notice the problem since this change.
  • Paul Escandon
    October 26, 2007 at 11:11 pm
    The AJA site says:
    AJA Driver Compatibility as of KONA Version 4.0 is as follows:
    FCP 6.0.x (Final Cut Studio 2)- Kona Driver version 4.0
    FCP 5.1.x – Kona Driver versions 3.1 through 3.4
    FCP 5.0.x – Kona Driver version 3 (first Universal Binary version)
    So I can’t really upgrade to 4.0 since I’m still running 5.1.4 based on this… oh and I am using QT 7.2 also.
