Activity Forums Apple Final Cut Pro Legacy Running FCP4.5 HD on a SINGLE chip g4 is bad?
  • Running FCP4.5 HD on a SINGLE chip g4 is bad?
    Posted by Keith Mann on June 23, 2007 at 1:50 am
    I’ve just had a FCP guru insist that only FCP 4.1 should run on a single chip G4.
    That running FCP 4.5HD on a single chip G4 is bad.
    That FCP 4.5HD needs a duo chip G4.
    My home machine is running a single chip 867 G4 and I’m wondering if I should go back to FCP4.1 I never do HD on this machine so I could probably do so.
    Any thoughts are most welcome.
    Rene Hazekamp replied 19 years, 2 months ago 4 Members · 3 Replies
  • Rich Rubasch
    June 23, 2007 at 3:06 am
    One option is to get a processor upgrade so your software sees the higher speed…with the right drives, things should work pretty well.
    Rich Rubasch
    Tilt Media
  • Eric Peterson
    June 23, 2007 at 3:25 am
    What would be bad about it? A friend still uses 4.5 on a 766 G4. Works fine. Slow, but still edits DV video.
  • Rene Hazekamp
    June 23, 2007 at 9:27 am
    nonsense
    people have always been to edit on powerbooks, even with fcp 5.0
    Ren
