Activity Forums Apple Final Cut Pro Legacy Running DVCPro HD on a G5
  • Running DVCPro HD on a G5
    Posted by Mmromo on March 19, 2007 at 3:30 am
    I’m going to purchase an Intel based G5. Can I run DVCProHD off an internal harddrive ATA7200rpm from Apple? Can I run it off an external Firewire 800?
    Enzo Tedeschi replied 19 years, 6 months ago 2 Members · 1 Reply
  • Enzo Tedeschi
    March 19, 2007 at 9:17 pm
    I’m assuming you mean a Mac Pro, not a G5?
    Regardless, you will do well to get yourself even a modest striped array – you will be able to do it (just) with 7200rpm drives (even the FW800), but it will give you problems once the drive starts filling.
    The Mac Pros have more than enough space inside to stick in 2 additional media hard drives, and RAID them in OSX. You’ll enjoy very few hiccups / frame drops and multiple streams will be a little easier. If you go external, consider the RAID drives from Lacie – you’ll have to go into the 1 to 2 TB range (I think) to find them.
    My two cents.
    Enzo Tedeschi
    ____________________________
    Editor
    http://www.outpostpps.com
    Sydney, Australia
    YouTube Channel – http://www.youtube.com/outpostpps
    Check out the Outpost Video Podcast – http://www.outpostpps.com/podcast/
