Activity › Forums › Adobe After Effects Expressions › Running counter, starting higher than 30,000
Posted by Mike Weber on November 2, 2005 at 11:53 pmI am using AE 6.5 I need to make a running counter, that counts down from 50,000,000 to 10 in about 3 seconds. The way I have done this kind of thing in the past is to make a new solid layer, and then add the Text>>Number effect onto it, and then adjust Value. (With “Composite on Original” unchecked. However, it seems that the high end limit is 30,000. I need to start at 50,000,000, so any ideas on how I can count down from higher than 30,000?
thanks
MikeLiran Tabib replied 10 years, 5 months ago 6 Members · 10 Replies -
Colin Braley
November 3, 2005 at 1:09 amI am not in front of my AE right now but you could try this:
– Create a new text layer
-add the following expression to sourcetext://–Begin expression
beginNum = 50000000;//Beginning number of counter
endNum = 10;//Ending number of counter
duration = 3;//duration of count down in seconds
linear(time, 0, duration, beginNum, endNum)//–End expression
~Colin
Mike Weber
November 3, 2005 at 6:09 pmHi, and thanks for your help. I’m still stumped, mostly because I don’t have much experience manipulating text layers, other than position, scale, etc. When I make a new text layer, do I have to first select something from the Animate menu (in the layer) before I can add an expression? Under the animate menu, there’s a choice for character value – is that what I want?
Then, I assume I select Selector>>Expression from the Add menu. (Again, in the layer). But then what exactly do I do? I tried opening up Expression Selector 1, and then pasted in your expression, over where it says selectorValue * textIndex/textTotal. I tried that, but nothing happens.
Again, thanks for your guidance. This is a whole new level of AE for me. I’ve gotten this far by reading the manual, but I’m not sure if I’m on the right track.
Mike
Colin Braley
November 4, 2005 at 3:13 amTry this:
-Twirl down the properties for your text layer. (you should see the text and transform properties)
-Twirl down the “text” property
-You should see an animatable value called sourcetext.
-Alt + click on the stopwatch and paste in my expression
-(instead of alt + clicking you can hightlight the property and go to animate > add expression if you want)
-That should be all you need to do~Colin
Mike Weber
November 4, 2005 at 6:01 pmWow, that worked! Thanks a lot. If you’re still in a giving mood, I have a couple of follow up questions. Is there a way to keep it in whole numbers, in other words, get rid of the decimal places? Also, would like to line up the “10” in the proper place at the end. Thanks a million –
Mike
Colin Braley
November 5, 2005 at 4:50 amI forgot to include the part that would round off the decimals when I originally posted. Try this:
Math.round( linear(time, 0, duration, beginNum, endNum) )all I did to round the number was used the statement Math.round(). To round a number to the nearest whole number use this, to make a number go up to the next whole number use Math.ceiling() and to simply drop the decimals (make it go down to the lower number) use Math.floor(). These prove invaluable when working with numbers. As for making the 10 line up in the proper place you need to set the anchor point of the text to a different spot. Refer to the manual or online help within AE to learn more about this if you don’t know what it is. Well that’s it, glad I could help.
~Colin
Mike Weber
November 6, 2005 at 9:03 pmThanks for all your help – you’ve saved me a lot of time & frustration! Our senior artist position is currently vacant, and so I’m stepping in to help out the best I can. Normally I (an editor) use AE to do relatively normal things like moves on stills, color keys, masking, etc. Usually I can figure things out (or at least fake it), but this one had me stumped. I don’t know the expressions features at all, so maybe I should get more acquainted. Thanks again –
Mike
Francisco Carreon
September 25, 2011 at 10:32 pmThis works great! Thank you.
I have a question regarding the expression; how can I make the number counter start at a particular frame not at the begging of the comp, go from one number to another one, pause and then go to another number.
For example:
2002 at frame 20 to 50000 2 sec later to 5000000 5 sec later, something like that.
Keenan Constance
November 1, 2013 at 12:05 pmThis works perfectly! Thanks so much. Is there any way to include things like currency (R) and decimal places. So that it counts from R0 – R16, 000, 000 for instance.
Saladino Alt
January 9, 2014 at 3:00 amThis script did it for me.
Counts numbers up or down with currency prefix and decimals.
Liran Tabib
April 22, 2016 at 7:21 amThis Counter preset will do the job:
https://www.vdodna.com/products/counter-preset/
