Activity Forums Apple Final Cut Pro Legacy Running Clips in Reverse
  • Running Clips in Reverse
    Posted by Gerry Bimm on November 29, 2006 at 8:02 pm
    I need to know the quick way to run a clip in reverse in my timeline. I used to know but have forgotten and the user manual doesn’t help much. I do recall some quality issues with video running in reverse. Any help is appreciated!
    Gerry Bimm replied 19 years, 9 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    November 29, 2006 at 8:13 pm
    Select the clip and hit apple-j and click the reverse button. The problem is that FCP does not (or used to not) reverse the field order if you are editing interlaced footage. Graeme Nattress had a plug-in that would reverse the field order for you. I have no idea if this feature has been updated in the most recent version of FCP.
    https://www.nattress.com/Free/freeFCP.htm
    Look at G Reverse.
    Jeremy
  • Gerry Bimm
    November 29, 2006 at 8:14 pm
    I did it using the reverse control in time remapping…is there another way to do it and keep the video quality? I had heard there was a filter available?
  • Gerry Bimm
    November 29, 2006 at 8:16 pm
    Thanks Jeremy…got it.
