Activity Forums VEGAS Pro Running clip less than its length
  • Running clip less than its length
    Posted by Kumar Reddy on July 2, 2010 at 11:51 am
    Hi, I have a quick question. I am kind of new to the Sony Vegas Platform. what should I do if I have to embed the clip or run the clip in less than it length.
    per suppose, I have a clip of 10 seconds in length and I want to run complete clip in less than 2 seconds. Do you guys have any clue how to accomplish that ?
    Kumar Reddy replied 16 years, 2 months ago 3 Members · 3 Replies
  • John Rofrano
    July 2, 2010 at 12:45 pm
    It’s not clear from your post if you want to stop at 2 seconds or speed it up to 2 seconds so here’s both methods:
    If you just want to shorted the clip to 2 seconds you would click on the right end of the clip and drag it in until it was 2 seconds long. You could also use the ‘S’ key to Split the clip at 2 seconds and use the delete key to delete everything after that, finally you could open the clip in the Trimmer and select the 2 seconds that you want and drag just those 2 seconds onto the timeline.
    If you want to speed the clip up so that the entire 10 seconds plays back in only 2 seconds then hold the Ctrl key while dragging the right edge inward and it will speed up the clip. Draging it longer will slow it down.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ben Edwards
    July 2, 2010 at 3:01 pm
    Welcome aboard;).
    There are lots of ways of only using part of the clip and you can even change its speed to make it shorted.
    I would advise you spend some time going through some basic tutorials, it will save you much time and frustration.
    Have a look at https://www.sonycreativesoftware.com/support/trainingvids.asp?prod=vegaspro (or https://www.sonycreativesoftware.com/support/trainingvids.asp?prod=moviestudio if you are using Studio), The trimming tutorial is the one I think you want.
    There is also lots of stuff on YouTube.
    Ben
  • Kumar Reddy
    July 2, 2010 at 8:55 pm
    Hi John –
    Thanks for interpreting my intention in the post. My question was regarding the second point. I wanted to run the clip in less than 2 seconds. And thanks a lot, for posting your reply. It was really helpful.
