Activity › Forums › VEGAS Pro › running 2 versions of Vegas
  • running 2 versions of Vegas
    Posted by Mel Perez on April 12, 2008 at 9:04 pm
    Hi..recently purchased Vegas 6 and decided to buy an upgrade to Pro8.I read Vegas 6 would no longer be able to read files once they are imported into Vegas 8. Am curious if it’s possible to run both versions of Vegas on the same computer? I would like to use what i already know on current projects while learning version 8? If so,would you know of any problems associated with doing this?… Thanks
    Mel Perez replied 18 years, 5 months ago 2 Members · 2 Replies
  • Edward Troxel
    April 12, 2008 at 10:18 pm
    Both versions install in separate folder and you can continue to run multiple versions just fine. I have many different versions installed on the same machine. However, once you save a file in a newer version, it can no longer be opened in an older version.
    Edward Troxel
    JETDV Scripts
  • Mel Perez
    April 13, 2008 at 12:55 am
    appreciate all your help…thanks again Edward
