Activity Forums Avid Media Composer Run two Xpress Pros off of one Mojo???
  • Run two Xpress Pros off of one Mojo???
    Posted by Kirk Stock on August 5, 2005 at 6:53 pm
    I am looking at expanding to a second editing bay. We currently have Xpress Pro with the Mojo and import everything from Beta SP. I was hoping to add a second Xpress Pro using the same Mojo and beta deck. Any thoughts would be appreciated.
    Kirk
    Michael Phillips replied 21 years, 1 month ago 2 Members · 1 Reply
  • Michael Phillips
    August 5, 2005 at 8:06 pm
    Shouldn’t be a problem as long as you are aware you can’ use the Mojo on two systems at the same time…
    As long as the versions of XPress Pro are the same you won’t have to worry about which FPGA is always getting loaded at launch.
    Michael
