Activity › Forums › Maxon Cinema 4D › Rubber Shoe Sole
  • Rubber Shoe Sole
    Posted by Vincent Rosati on August 9, 2009 at 5:58 pm
    Hello All,
    I’m trying to put a shader on some polygons, to make the rubber sole of a shoe. When I use Displacement, the surrounding polys are effected. I don’t want that. I considered simply extruding the ‘sole’ polys, but I suspect there should be a way to confine the material to only effect the sole.
    Also, is there a way to use this shader to also add a little bit of thickness to the sole, or does that just take me back to extruding?
    https://www.newinelabs.com/rosati/tutorials/assets/c4d_shoe_sole_r10.c4d
    Vince
    *Please remember to Rate our replies and check Solution if solved. Also, we do this out of love and fun, so its always nice to recieve a Please and Thank You! 🙂
    Brian Jones replied 17 years, 1 month ago 2 Members · 1 Reply
  • Brian Jones
    August 11, 2009 at 1:46 am
    you’d probably have to use Sub-Poly displacement to get the texture to limit itself to the selection
