  • Posted by Jennifer Arani on August 7, 2009 at 12:00 am
    Hello,
    Sorry I’m back.
    Okay here are my native settings of my clips
    Frame Size – 720X480 NTSC DV (3:2)
    Pixel Apect Ratio (NTSC – CCIR 601 /DV (720×480)
    QT Video Settings DV/DVCPRO-NTSC
    I need to set my sequence settings due to imported items from camtasia
    Frame size 640X480
    Pixel Aspect Ratio Square
    QT Video Settings – I can use whatever you guys suggest.
    Final output – 640X480 and that footage may be compressed by my partners to the next size down for web.
    So here is the deal…. When I change the sequence to 640X480 I lose the options on my RT settings. I don’t know why it happens but I do know it happens when I change the sequence settings. Please help
    Jennifer Arani replied 17 years, 1 month ago 2 Members · 2 Replies
  • Rob Grauert
    August 8, 2009 at 10:30 pm
    No. Edit with a sequence that matches the specs of your footage. Then use Compressor to export a file that meets your clients requirements.
    Robert J. Grauert, Jr.
    http://www.robgrauert.com
  • Jennifer Arani
    August 9, 2009 at 12:49 am
    YOU ARE THE MAN!!!!!!
    The last video I did like this was pure mess. Due to my ignorance of aspect ratio’s and resolution settings.
    I just output to compressor has you recommend and it was clear as a bell!
    If no one else tells you today you are appreciated
