Activity Forums Apple Final Cut Pro Legacy RT playback problems
  • RT playback problems
    Posted by Cameron O’donohue on April 11, 2012 at 9:25 pm
    Hi all,
    This has been covered before, but I can’t seem to get it right. I would appreciate help. I am using FCP 6 on the following system:
    2.5 GHz Intel Core 2 Duo (early 2008 MacBook Pro) with 4 GB 667 MHz DDR2 SDRAM.
    I pulled in some dvd footage using ISkysoft DVD ripper, using the FCP preset. Files imported have the following properties: H.264, 1280X720, 25fps, with a data rate of 1.2 MB/S. My system should be able to handle it but whenever I drop an effect on a clip I am getting the RT playback error “Warning — Dropped Frames”. (eg 1 from https://support.apple.com/kb/TS1165).
    Thanks for the help.
    Cameron O’donohue replied 14 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
