Activity Forums Blackmagic Design RT in final cut pro
  • RT in final cut pro
    Posted by Levan Bakhia on December 11, 2005 at 11:13 am
    When in sequence setting (in final cut) I use blackmagic in compressor (quicktime video settings) in my RT extreme menu, all the setting disappear, I alno get option “Play base layer only”. and as I understand this means that I don’t get the real time in Final Cut Pro. So why is that?
    And also can anyone tell me difference between:
    Blackmagic 10 bit (DV10) and Blackmagic RGB 10 bit
    or
    Blackmagic 8 bit (2Vuy) and 8 bit (DV00)
    is blackmagic RGB 10 bit better than uncompressed 10bit 4:2:2? Please consider, that I shoot on 35mm film, than telecine it at 1920X1080 resolution, and after editing I sometimes print back to film. So is blackmagic good codec for using this way?
    Oh, and I have blackmagic HD pro (single link).
    Levan Bakhia replied 20 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
