Activity Forums Apple Final Cut Pro Legacy RS 422 with a USB adaptor crashing FCP
  • RS 422 with a USB adaptor crashing FCP
    Posted by Jim Mcnally on September 29, 2005 at 10:06 pm
    Lots of fun with FCP today.
    This week I replaced my Media 100 system with a Dual 2’s G5 for broadcast commercial work. I use 2 edit suites in my shop, and the new G5 (On FCP 4.5) runs alongside a G4 based Final Cut System which I’ve had for years.
    The issue that’s been coming up this week has been deck control. I run 2 decks, a Sony BVW-75 Betacam, and a Sony DSR-45DV Deck. What I need to do is be able to control both decks from both edit suites. This was never an issue using the Media 100 system and the G4 together, but with the new G5, I’ve had to invest in a USB to Serial adaptor to achieve RS-422 control… and it won’t work.
    Everything is still 100% on my G4. I can control and capture from DV, and I can also control the Beta from RS-422 (an internal card) while I capture through a DV breakout box. Because of this second unit, I know there are no hardware issues.
    However, no matter how I configure my USB to Serial adaptors to get the G5 to try and control my betacam deck, I get about one second of ‘VTR OK’ … then I beachball and have to force quit. Video comes in just fine from the Beta, converted to DV, but no deck.
    I’ve swapped out cables, updated drivers, reinstalled FCP, caught up on software updates, and even purchased a backup USB/Serial connector. Nothing works.
    One thing that I’m aware of is that as I configure the USB/Serial port which is created when I install these adaptors, the name of the port is very slightly different in my network prefs, compared to when I select that port in FCP’s A/V settings for device control… suffixed with a ‘0’ in the name or something.
    Any ideas?
    Bryce Whiteside replied 20 years, 7 months ago 2 Members · 3 Replies
  • Bryce Whiteside
    September 29, 2005 at 10:26 pm
    The Keyspan USB adapter worked on my G4 and PVW-2800 setup.
    Which brand are you using?
    Inquiring minds…
    Bryce
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
  • Jim Mcnally
    September 29, 2005 at 10:29 pm
    The first one was from Byterunner.com which was usb-comi model. The second one was from iogear.
    Jim
  • Bryce Whiteside
    September 29, 2005 at 10:44 pm
    I know that the Keyspan USA-28x USB to twin RS422 adapter is the most recommend or qualified adapter.
    Go to https://www.google.com and copy paste the following keywords in the search window:
    Keyspan USB “RS-422” setup device settings FCP OR “Final Cut”
    HTH,
    Bryce
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
