Activity Forums Avid Media Composer RS-422 AND RS-232???
  • RS-422 AND RS-232???
    Posted by Satesh Ramjattan on August 26, 2006 at 4:23 pm
    Hello,
    I am looking into buying a professional DV deck for my Xpress Pro System. The deck I want offers the RS422 option for deck control. My question is, How do I know which one I have on my PC? I looked up both RS422 and RS232 and they both look the same. I checked my MoBo manual and it refers to it as only COM1. I have a Tyan Thunder i7525 S2676.
    Can someone help me or point me in the right direction?
    thanks
    Bill Stephan replied 20 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • David Braswell
    August 26, 2006 at 5:23 pm
    AFAIK, your computer alone will not support either of those two protocols. You will need external hardware to plug into your serial port to get that working. The Mojo will handle this for you. Aside from that you can Google a product called “Rosetta Stone”, although I don’t think it will be of any benefit to your Avid application. The real issue is that your computer OS alone doesn’t understand the protocols (other than firewire controlled DV decks/cameras).
  • Satesh Ramjattan
    August 26, 2006 at 5:53 pm
    “The Mojo will handle this for you.” Excuse my IT ignorance, but I don’t understand. I have a Mojo and a firewire camera and I still cannot do batch capture or digital cut. From research, you cannot perform these via firewire. Can you tell me what I need to get these features working? The deck I am interested in buying is the JVC BR-DV3000U.
  • David Braswell
    August 27, 2006 at 5:47 am
    Apologies first, I thought the Mojo had a 422 port; it doesn’t. No matter, it was designed to accelerate realtime performance as well as capture and digital cut to camera. Not sure of your research, but I assure you that you can batch capture and cut through firewire. I don’t know if the JVC deck you mentioned is on Avid’s approved hardware list, but if it is, you should be able to connect it via firewire to either the Mojo or straight to your computer and perform both functions. Avid does warn that digital cut through firewire is not frame-accurate, but you can crash record. If I had your problem I would probably try disconnecting the Mojo and checking camera control via firewire straight to the computer. The help file concerning digital cut and capture is pretty thorough.
  • Satesh Ramjattan
    August 27, 2006 at 2:58 pm
    [maverick13] “Aside from that you can Google a product called “Rosetta Stone”, although I don’t think it will be of any benefit to your Avid application. The real issue is that your computer OS alone doesn’t understand the protocols (other than firewire controlled DV decks/cameras).”
    Could you explain why it would not benefit? The Avid manual talks about a converter like it.
  • David Braswell
    August 27, 2006 at 7:27 pm
    My mistake (again :P). Here is an Avid support article that describes a setup like you’re trying to achieve (Avid, Mojo, RS-422 controlled deck). It uses the Rosetta stone and even mentions that Avid sells it.
    RS 422 setup.
  • Jon Zanone
    August 28, 2006 at 3:30 am
    The Rosetta Stone (and others like it) translates an RS-422 signal to a serial signal and vice versa – your RS-422 deck can be controlled by the Avid via the serial port. The JVC deck mentioned earlier works with the Avid via firewire, but is problematic in my experience.
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • Bill Stephan
    August 28, 2006 at 3:55 pm
    The ports on your computer are RS-232, and the ports on all professional video equipment are RS-422. You need to obtain a converter such as a Rosetta Stone (there are other brands) to connect the two. You can buy cables that have the Rosetta Stone built into the plug on one end, although these usually come from OEMs that include them with their devices.
    Mojo doesn’t help with VTR remote unless you are using firewire VTR control. You are far better off using RS-422 remote if your devices have it.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
