Activity › Forums › Adobe After Effects Expressions › rove across time in one axis
  • rove across time in one axis
    Posted by Flitch13 on May 14, 2007 at 12:19 am
    I was wondering if it is possible to rove position keyframes across time in a single axis (x-axis). I am assuming if this is possible it would be done with expressions not some setting or effect that I am unaware of.
    Lord Scales replied 19 years, 4 months ago 3 Members · 2 Replies
  • Mike Clasby
    May 14, 2007 at 5:36 am
    I don’t quite get it, you want to rove the x keyframes over time and leave the y keyframes unchanged? If you stretched out the x, what would the following y’s do, the y’s in thaat newly create space (or shrunken space)stay the same as the last y keyframe before the stretch?
  • Lord Scales
    May 14, 2007 at 8:56 pm
    There is a Preset in Effects and Presets (Window > Effects and Presets) called Separate XYZ (or something like this). With this preset, you can animate separately the positions so you can rove them separately also.
    Lord Scales
