Activity Forums Zaxwerks rounding the front face of text
  • rounding the front face of text
    Posted by David Miller on November 14, 2011 at 10:08 pm
    Does anyone know how to round the front face of the text or to chisel it to a point like the Harry Potter text in ProA 5?
    thanks
    David
    Edward Wu replied 14 years, 10 months ago 3 Members · 2 Replies
  • Fernando Mol
    November 14, 2011 at 11:39 pm
    Bevels use flat fronts. You can experiment with the Edge Offset and Bevel Scale using the bevel “Flare, Straight”. But that will hardly work on irregular fonts, like the Harry Potter one.
    It’s a good question, I wonder if someone can come with a better tip.
  • Edward Wu
    November 15, 2011 at 8:19 pm
    Hi David,
    Right. You can either play with the Edge Offset, or manually edit the text outline in the Drawing Window so that the text is really thin. Then you can apply a Round Bevel like Fernando suggested, or create your own bevel in the Profile Editor.
    If you have 3D Serpentine, you can try using text as the Serpentine Body, and then applying a round end cap.
    Hope this helps.
    Best,
    Edward
