Activity › Forums › Apple Final Cut Pro › Rounding the edges of a clip in Final Cut Pro X
  • Rounding the edges of a clip in Final Cut Pro X
    Posted by Steve Taylor on July 26, 2014 at 5:04 pm
    I’ve used the distort tool before to fit a clip over a tv screen as if to look like the clip is on tv, but can’t figure out how to round the edges to fit a rounded vintage tv screen instead of a perfect rectangle. Can anyone help?
    Bret Williams replied 12 years, 2 months ago 4 Members · 6 Replies
  • Bret Williams
    July 26, 2014 at 10:29 pm
    There’s an effect called mask. You can control the roundness. You can add a little feather too. Use that to get the rounded square, then distort it into the TV.
  • Kerry Brown
    July 27, 2014 at 4:49 am
    Go to effects- distortion- crop and feather
  • Bret Williams
    July 27, 2014 at 2:44 pm
    Good call! I didn’t realize crop and feather had roundness control. Makes it almost exactly the same effect as “mask” except mask gives you 4 discreet corners that don’t have to be perpendicular.
    Why they don’t just add roundness and feather to the crop controls in the inspector is kinda bizarre.
  • Craig Alan
    July 27, 2014 at 9:33 pm
    generally, lots of overlap between stuff that can be done directly in the timeline/inspector/viewer vs adding an effect from the effect’s browser. I assume there is a technical difference on how these are being applied.
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
  • Steve Taylor
    July 27, 2014 at 11:36 pm
    All great suggestions, but I’m still a little restricted with the shape and rounding controls. Is there a way to provide even more freedom with shaping the clip? More free form? Thanks.
  • Bret Williams
    July 27, 2014 at 11:51 pm
    Ah, round the edges, not the corners. You can create a custom matte in just about any drawing app. PS, Illustrator, iDraw, etc. Or you could buy a plugin like sliceX from CoreMelt and draw mattes right in X and track them to the TV if need be.
