Activity › Forums › Maxon Cinema 4D › rounded square button
  • rounded square button
    Posted by Jose Villanueva on May 19, 2010 at 6:47 pm
    thanks in advance for this totally rookie question. i have a square path with rounded corners that i’ve imported and extruded. now all i need to do is give the front and the back some rounding without affecting the outside edges. tried fillet and bulge and obviously didn’t work for me. any help or different approach would be great. i suck…make me better, thanks.
    Jose Villanueva replied 16 years, 4 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    May 19, 2010 at 7:56 pm
    I would use a FFD (free form deformer). First make sure the spline you’re extruding has at least 4 – 5 points on each side. If not use Function>subdivide. Then change the extrude caps from the default ngons to quadrangles>regular grid. That will give you enough geometry to deform.
  • Jose Villanueva
    May 19, 2010 at 10:57 pm
    thank you very much adam, that worked perfectly 🙂
