Activity Forums DaVinci Resolve Round Trip to FCP7 and DaVinci, Translation Document File?
  • Round Trip to FCP7 and DaVinci, Translation Document File?
    Posted by Kyle Gentz on September 15, 2011 at 7:00 pm
    After I render in DaVinci and I try to open the xml, Final Cut Pro 7 asks me to select a “Translation Document File”, does anyone know what that is? How to i get the project back to FCP.
    Live, Life and the pursuit of Pixels
    Alex Yorchak replied 14 years, 9 months ago 4 Members · 3 Replies
  • Dan Moran
    September 15, 2011 at 7:11 pm
    That doesn’t sound normal, maybe your XML isn’t working correctly. Can you try a re-export ?
    Also it would be helpful if you posted back in the same thread as before to make it easier to follow for others!
    D
    Dan Moran
    DaVinci Application Specialist
    Blackmagic Design EMEA
  • Christopher Tay
    September 16, 2011 at 3:22 pm
    I’ve seen this message recently when I tried to import an XML that is meant for FCP7 into FCP6.
    Check that you are indeed running FCP7 when you are importing the XML exported from Resolve.
    -chrispy
  • Alex Yorchak
    December 2, 2011 at 11:28 pm
    I’m having the same problem. Any luck or new developments, kyle?
