Roughen Edges Effect On Layer Mask Weirdness
Hi all,
OK so here’s the problem…. I have applied the roughen edges effect to a solid layer; this solid layer also contains a mask. The layer is then switched to 3D and a camera is keyframed to track towards the layer on the Z axis. Everything looks fine until I turn on the continuously rasterize switch, whereupon the roughen edges effect appears to move separately from the edges of the masked layer it is applied to. It gives the illusion I have animated the effects evolution property when in fact I haven’t.
I have tried following the instructions from this thread –
https://forums.creativecow.net/thread/2/919843#919946
pre-composing etc but this hasn’t worked. I understand it is an issue with the way the attributes are stacked on the layer, but I can’t seem to figure out a work around.
Any help or suggestions would be hugely appreciated.
Cheers
