Activity Forums Adobe After Effects Rotoscope/Paintbrush question
  • Rotoscope/Paintbrush question
    Posted by Jeff Belcher on March 1, 2012 at 2:50 pm
    Just a quick little question that I’m having a little trouble trying to Google.
    I’m using AfterEffects to draw over a video for a little rotoscoping project. It’s been a while since I’ve used the program. I can only Paintbrush when in a Layer Viewer, and since I’m using a Solid layer to do so, the video disappears when I go into the Viewer.
    Any way to get around this? I want to frame by frame animate but I need the video to reference from.
    Angie Taylor replied 14 years, 3 months ago 2 Members · 1 Reply
  • Angie Taylor
    May 10, 2012 at 8:22 am
    Hi there,
    I feel your pain, I’d love to be able to paint directly in the comp panel too.
    As a workaround you can duplicate a copy of your video and use that to paint on instead of using a solid layer. Double-click it to open it in the Layer Panel and choose RGBA as the target chaneels. Paint away.
    To see your comp update as you paint, go to View > New Viewer. Place the two viewers side by side. In one select the comp panel and lock it. In the other select the Layer panel, it should also be locked. This way you can paint in the Layer panel and see your comp panel update simultaneously.
    All workarounds but they help I hope 🙂
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
