Activity › Forums › Adobe After Effects › rotoscope question
  • rotoscope question
    Posted by Frank Ruggiero on September 30, 2005 at 3:50 pm
    Dear Cow People,
    Can anyone tell me what I am doing wrong? I rotscoped a small segment of a non-interlaced graphic. When I render it with fields I can see that the rotoscope does not line up. When I render it without fields, it is perfect.
    Am I stuck to rendering progressively? I want to render with fields since I am going to digital beta.
    Or is there a way to see where my masks are on each field in AE before I render? Or would this be making double the work for myself? I am just not sure what the best workflow is for a rotoscope,
    thanks in advance.
    -Frank
    Frank Ruggiero replied 21 years ago 2 Members · 2 Replies
  • Steve Roberts
    September 30, 2005 at 3:59 pm
    I’m not sure of what you need, so chew on these:
    1. You don’t have to render fields for video. I rarely do. Video can still accept the non-field-rendered footage and be “satisfied” that it is getting field-rendered video from you … it’s just that both fields are identical. You see?
    2. Generally, when rotoscoping interlaced footage, you drop the interlaced footage into a 59.94 fps comp, so you can see each field, then you render at 29.97.
    Does that help?
    Steve
  • Frank Ruggiero
    September 30, 2005 at 5:47 pm
    Thanks. Yes that helps.I guess if I am doing large compositing with many different elements, it would be best not to render with fields on while rotoscoping. Or rotoscope what I need first (in 59.94) render it and then bring it back into my composite.
    -Thanks.
