Activity Forums Adobe After Effects Rotobrush Selection Problems
  • Rotobrush Selection Problems
    Posted by Ryan Castle on November 17, 2011 at 4:37 pm
    When I make a selection, and move the frames ahead, the selection keep overlapping into the background, or moving inwards into the object I’m trying to select. I only want it to move when the object makes a drastically noticeable change, and not re-calculate until said movement is made. Is there a way to make it less sensative?
    (If it helps, me video is just that of a man talking, and his head move a little, and it is the head I’m trying to capture)
    Michael Szalapski replied 14 years, 9 months ago 2 Members · 1 Reply
  • Michael Szalapski
    November 21, 2011 at 6:52 pm
    I’m not quite following what your problem is, but it sounds like a basic misunderstanding of how to use the Roto Brush. Go through all the resources here: [link] and it should help you.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
